Onko tiedossa eroaako cossu 2wd kytkinkopan kiinnitys vaihteistoon mitenkään verrattuna siihen amerikan mallin lähes vastaavaan laatikkoon.
asia kiinnostaa tämän takia varmaan muitakin.
eli meniskö T-56:seen cossun kytkinkoppa kiinni tolla valmiilla sovitteella. Ja pidemmällä kytkinakselilla.
tietysti kytkinlevy jutska mutta noitahan patentoidaan muutenkin ties mistä malleista. ja sorvataan teräs VP.
http://cgi.ebay.com/ebaymotors/T56-Tran ... enameZWD1V
Billet Steel T56 Mounting Adaptor Plate
Auction is for a new billet steel T56 adaptor plate.
* Plate will allow you to remove a Muncie, T10, Saginaw or T5 transmission, mount a T56 transmission (LS1 or Viper) and retain the use of your original bell housing and clutch linkage. An LT1 T56 may also be used, but the input shaft must be changed to the longer LS1 input.
* Plate has dual bolt patterns, allowing you to mount transmission straight up or at 17 degrees, as needed for Camaro and Firebird applications.
* Plate comes with all mounting hardware to mount plate to trans and bell housing.
* Fits many GM applications, Chevrolet, Chevelle, Camaro, Pontiac, Oldsmobile, Buick, and many other GM models. Please email with questions regarding fit and application.
Please contact us at thegearbox@aol.com or 734-793-0727 with any questions on this item.
Actual shipping will be applied.
We accept Paypal, Visa, MC, Discover, Amex or money orders.
toinen löyty tällänen eli vain ylimmät reiät ei passaa ohc lohkoon niinhän se oli Pintosta
http://cididit.com/products.htm
2.3 Liter Ford Bellhousing Adapter Plate
The adaptor plate is constructed of billet aluminum and is designed to convert any Ford 2.3L bolt pattern to the standard Ford small block or 5.0 bellhousing bolt pattern. This conversion enables the use of the larger transmission components including the automatic transmissions used with small block Fords.
Note: When using this adaptor plate with a manual transmission, the use of a zero balance small-block Ford flywheel with a 2.3L crank shaft bolt pattern is required. These can be purchased from SPEC (Part # SFO5A-2).
This is complete kit and includes the necessary hardware for installation.
2wd cossu T5 kytkinkoppa ja T56 yhteen
