Colognen stroukkaus
jouni
Colognen stroukkaus
Tästä on muistaakseni ollut aiemminkin puhetta, mutta onkos kukaan täällä tehnyt noita?
Tuossa specialised enginesin ( www.specialisedengines.co.uk )sivuilta poimittua tekstiä:
Specification as Stage 3.0 - 3.1+ (See Ref 10)
In Addition : Block overbored to 96mm. With heavy duty, modified and balanced pistons.
Crankshaft stroked to 73mm. Con-Rods modified and balanced, with fully floating gudgeon pins.
PRICE : £3448.00
3.5 & 3.6 Conversion
When we first produced the 3.0 - 3.1+ conversions in 1988, our main concern was for reliability and smoothness, closely followed by improvements in both torque and BHP, aligned with reasonable fuel consumption and price. All this equal a good fast road car - not and unreliable ‘cammy’ and ‘juicy’ semi-race type.
We believe we achieved all our aims.
In developing the 3.5 - 3.6 range, we hoped for similar gains. Initially we tested three ‘stroker’ crankshafts of 84, 85 and 86mm, with various bore sizes.
All gave considerable gains in torque, but small, rather disappointing gains in BHP compared to 3.0+ and 3.1+ engines, due to the restrictions imposed by the standard electronic fuel injection system (EFI) used by Ford. Although with carburettored or earlier Bosch type injection systems, BHP is improved.
We can supply a remapped addition to the EFI system at an extra cost of £200.00 + VAT (Fitted).
We have found that a stroker crankshaft of 84.32mm, with a choice of bore sizes as above giving 3.5 to 3.6 litre is the most reliable and fuel efficient of these conversions.
ENGINE PRICED FROM : £3879.00
Eli ei ihan halpaa hommaa. Mutta laitoin ihan piruuttani kysymyksen toimittaisivatko pelkät kampiakselin, kiertokanget ja männät. Eikä kansipahvitkaan olisi tietty pahasta...Koko myllyä ei kuitenkaan ole mitään järkeä lähteä englannista tilaamaan. Koneistuksethan saisi tehtyä täälläkin.
Ei varmaan kuitenkaan pöllömpi mylly voisi olla ahdettu 3.6 V6...? Ainakaan 3-reikäkansilla.
PRICE : £3448.00
Vee niinko Voima!
Hmmm... Eiköhän nuo setit voisi sopia ihan mihin vaan Colognen lohkoon?
Onko niitä Ruotsissa enempi kuin jossain muualla Euroopassa?Hessu kirjoitti:Mitä jos raahaisit Ruotsista 4.0 koneen, tulisi varmasti halvemmaksi ja vääntöä piisaa
Hessu
Ei välttämättä. Tuo on kuitenkin lähin/helpoiten luoksepäästävä paikka, jossa niitä yleisesti on saatavilla. En kiellä hakemasta vaikka jenkeistä asti, ja voihan tuurilla täältäkin mokoman löytää.MouTine kirjoitti: Onko niitä Ruotsissa enempi kuin jossain muualla Euroopassa?
tanari
RS2600
tanari
ford aerostar ja ford bronco ja ford maasturit ja pickapitRS2600 kirjoitti:Missä vehkeissä noita 4litrasia on ja mikä poraus/iskuHessu kirjoitti:Mitä jos raahaisit Ruotsista 4.0 koneen, tulisi varmasti halvemmaksi ja vääntöä piisaa
4.0 on muuten sama kuin 2.9 mutta deckki korkeus on suurempi ja isku eri, poraus on muistaakseni sama kuin 2.9 koneessa.
tanari
Hessu
MoloA
Kaivetaan nyt tämä threadi haudastaan, jonkin verran eroja on selvitelty myös osoitteessa
http://agnes.homelinux.com/ford/
#682
jouni
Pistäkääs nyt joku pähkinänkuoressa infopaketti siitä mikä sopii mihinkin ja mitä siitä tulee. Tsekkasin MoloA:n linkin ja eipä nyt ihan bolt-on hommalta näyttänyt. Meneekö nyt tuo 4.0 kampura vanhempaan Cologneen? Entäs Cossu?
Hessu
Kuuleman mukaan 2.9 kampi 2.8 lohkossa on jo aika tiukka, mahdollisesti joutuu hiukan vinguttamaan kiertokankien kohdalta. 4.0:ssa olisi vielä 12mm pidempi isku eli suuren luokan ongelmia saattaisi olla luvassa. Cossun lohkosta en tiedä, mutta miten olisi 4.0 alakerta cosan kansilla?
Arto65FB
Linkutin ei taida enää toimia?MoloA kirjoitti:Kaivetaan nyt tämä threadi haudastaan, jonkin verran eroja on selvitelty myös osoitteessa
155hp ja ~325nmBootsi kirjoitti:Paljonkos tuossa 4 litrasessa on vakiona tehoja.
Laatikot ilmeisesti käy ristiin 2.8 <--> 4.0
