Colognen stroukkaus
jouni
Colognen stroukkaus
Viesti Kirjoittaja jouni » To Kesäkuu 24. 10:50:21 2004
Tästä on muistaakseni ollut aiemminkin puhetta, mutta onkos kukaan täällä tehnyt noita?
Tuossa specialised enginesin ( www.specialisedengines.co.uk )sivuilta poimittua tekstiä:
Specification as Stage 3.0 - 3.1+ (See Ref 10)
In Addition : Block overbored to 96mm. With heavy duty, modified and balanced pistons.
Crankshaft stroked to 73mm. Con-Rods modified and balanced, with fully floating gudgeon pins.
PRICE : £3448.00
3.5 & 3.6 Conversion
When we first produced the 3.0 - 3.1+ conversions in 1988, our main concern was for reliability and smoothness, closely followed by improvements in both torque and BHP, aligned with reasonable fuel consumption and price. All this equal a good fast road car - not and unreliable ‘cammy’ and ‘juicy’ semi-race type.
We believe we achieved all our aims.
In developing the 3.5 - 3.6 range, we hoped for similar gains. Initially we tested three ‘stroker’ crankshafts of 84, 85 and 86mm, with various bore sizes.
All gave considerable gains in torque, but small, rather disappointing gains in BHP compared to 3.0+ and 3.1+ engines, due to the restrictions imposed by the standard electronic fuel injection system (EFI) used by Ford. Although with carburettored or earlier Bosch type injection systems, BHP is improved.
We can supply a remapped addition to the EFI system at an extra cost of £200.00 + VAT (Fitted).
We have found that a stroker crankshaft of 84.32mm, with a choice of bore sizes as above giving 3.5 to 3.6 litre is the most reliable and fuel efficient of these conversions.
ENGINE PRICED FROM : £3879.00
Eli ei ihan halpaa hommaa. Mutta laitoin ihan piruuttani kysymyksen toimittaisivatko pelkät kampiakselin, kiertokanget ja männät. Eikä kansipahvitkaan olisi tietty pahasta...Koko myllyä ei kuitenkaan ole mitään järkeä lähteä englannista tilaamaan. Koneistuksethan saisi tehtyä täälläkin.
Ei varmaan kuitenkaan pöllömpi mylly voisi olla ahdettu 3.6 V6...? Ainakaan 3-reikäkansilla.
Vee niinko Voima!
Viesti Kirjoittaja MouTine » To Kesäkuu 24. 12:19:53 2004
Hmmm... Eiköhän nuo setit voisi sopia ihan mihin vaan Colognen lohkoon?
Hessu
Viesti Kirjoittaja Hessu » To Kesäkuu 24. 12:32:05 2004
Mitä jos raahaisit Ruotsista 4.0 koneen, tulisi varmasti halvemmaksi ja vääntöä piisaa 8)
Viesti Kirjoittaja MouTine » To Kesäkuu 24. 12:39:55 2004
Hessu kirjoitti:Mitä jos raahaisit Ruotsista 4.0 koneen, tulisi varmasti halvemmaksi ja vääntöä piisaa 8)
Onko niitä Ruotsissa enempi kuin jossain muualla Euroopassa?
Hessu
Viesti Kirjoittaja Hessu » To Kesäkuu 24. 13:00:42 2004
MouTine kirjoitti: Onko niitä Ruotsissa enempi kuin jossain muualla Euroopassa?
Ei välttämättä. Tuo on kuitenkin lähin/helpoiten luoksepäästävä paikka, jossa niitä yleisesti on saatavilla. En kiellä hakemasta vaikka jenkeistä asti, ja voihan tuurilla täältäkin mokoman löytää.
tanari
Viesti Kirjoittaja tanari » To Kesäkuu 24. 13:21:13 2004
olis tarkotus epäkeskohioututtaa kampura ja chevyn 5.7" veivit männistä en vielä tiedä, pitää mitata ja todenäkösesti jokatapauksessa niitäkin joutuu koneistamaan :lol:
RS2600
Viesti Kirjoittaja RS2600 » To Kesäkuu 24. 17:42:52 2004
Missä vehkeissä noita 4litrasia on ja mikä poraus/isku
tanari
Viesti Kirjoittaja tanari » To Kesäkuu 24. 18:23:29 2004
RS2600 kirjoitti:
ford aerostar ja ford bronco ja ford maasturit ja pickapit :wink:
4.0 on muuten sama kuin 2.9 mutta deckki korkeus on suurempi ja isku eri, poraus on muistaakseni sama kuin 2.9 koneessa.
Viesti Kirjoittaja jjs » To Kesäkuu 24. 23:15:01 2004
4.0 vs. 2.9; on aikalailla eroja...
tanari
Viesti Kirjoittaja tanari » Pe Kesäkuu 25. 0:10:02 2004
jjs kirjoitti:4.0 vs. 2.9; on aikalailla eroja...
mutta eikö lähes kaikki osat käy ristiin? kampura ja kiertokanget ja männät on tietysti erillaisia.
Viesti Kirjoittaja jjs » Pe Kesäkuu 25. 2:12:18 2004
Öljypohja ei käy (on leveämpi 4,0), imusarja ei käy, kannet ei käy (venttiilit 4,0 samat kuin kaasari 2,3-2,8:ssa..). "Apulaitteet" kuten öljypumppu jne sopivat ristiin.
Hessu
Viesti Kirjoittaja Hessu » Su Kesäkuu 27. 14:25:56 2004
4.0 sylinterimitat on 100x84. Mitähän jos ottaisi siitä koko alakerran, niin ei tarvitse nakerrella turhia. 4x4 öljypohjia on noihin kuulemma saatu menemään, millähän konstilla?
MoloA
Viesti Kirjoittaja MoloA » Ti Lokakuu 19. 16:58:02 2004
Kaivetaan nyt tämä threadi haudastaan, jonkin verran eroja on selvitelty myös osoitteessa
http://agnes.homelinux.com/ford/
#682
jouni
Viesti Kirjoittaja jouni » Ti Lokakuu 19. 20:08:15 2004
Jos joku on oikeasti kiinnostunut 2.8:n stroukkaamisesta, niin noita 4.0 V6 kampuroita saa hiottuna laakereineen n. 450-500e hintaan alla olevasta numerosta:
02-5387091
Tyypin/puljun nimeä en muista, mutta tuo jenkkiautoihin osia (yllätys yllätys) jenkeistä.
Viesti Kirjoittaja MouTine » Ti Lokakuu 19. 22:07:00 2004
Pistäkääs nyt joku pähkinänkuoressa infopaketti siitä mikä sopii mihinkin ja mitä siitä tulee. Tsekkasin MoloA:n linkin ja eipä nyt ihan bolt-on hommalta näyttänyt. Meneekö nyt tuo 4.0 kampura vanhempaan Cologneen? Entäs Cossu?
Hessu
Viesti Kirjoittaja Hessu » Ke Lokakuu 20. 8:09:25 2004
Kuuleman mukaan 2.9 kampi 2.8 lohkossa on jo aika tiukka, mahdollisesti joutuu hiukan vinguttamaan kiertokankien kohdalta. 4.0:ssa olisi vielä 12mm pidempi isku eli suuren luokan ongelmia saattaisi olla luvassa. Cossun lohkosta en tiedä, mutta miten olisi 4.0 alakerta cosan kansilla? :P
Arto65FB
Viesti Kirjoittaja Arto65FB » Ti Marraskuu 16. 13:00:51 2004
MoloA kirjoitti:Kaivetaan nyt tämä threadi haudastaan, jonkin verran eroja on selvitelty myös osoitteessa
Linkutin ei taida enää toimia?
Bootsi
Viesti Kirjoittaja Bootsi » Ti Marraskuu 16. 18:59:37 2004
Paljonkos tuossa 4 litrasessa on vakiona tehoja.
Laatikot ilmeisesti käy ristiin 2.8 <--> 4.0
Viesti Kirjoittaja puuhapete » To Marraskuu 18. 17:22:31 2004
Bootsi kirjoitti:Paljonkos tuossa 4 litrasessa on vakiona tehoja.
155hp ja ~325nm :?
